Có thể giả lập Switch Layer 3 bằng NM-16ESW trong Dynagen không ?
  • Có thể giả lập Switch Layer 3 bằng NM-16ESW trong Dynagen không ?
    - bạn có thể dùng module NM-16ESW để giả lập switch layer 2 trong Dynagen (cấu hình VLAN, trunking...), nhưng có thể dùng nó làm switch layer 3 được ko ?
    + NM-16ESW hỗ trợ:
    •Cisco IOS Release 12.3 or later release
    Prerequisites for the Cisco EtherSwitch Network Module
    •Basic configuration of the Cisco 2600 series, Cisco 3600 series, or Cisco 3700 series router
    In addition, complete the following tasks before configuring this feature:
    •Configure IP routing
    For more information on IP routing, refer to the Cisco IOS IP Configuration Guide
    •Set up the call agents
    For more information on setting up call agents, refer to the documentation that accompanies the call agents used in your network configuration.
    + những điểm còn hạn chế của NM-16ESW:
    Restrictions for the Cisco EtherSwitch Network Module
    The following functions are not supported by the Cisco EtherSwitch network module:
    •CGMP client, CGMP fast-leave
    •Dynamic ports
    •Dynamic access ports
    •Secure ports
    •Dynamic trunk protocol
    •Dynamic VLANs
    •GARP, GMRP, and GVRP
    •ISL tagging (The chip does not support ISL.)
    •Layer 3 switching onboard
    •Monitoring of VLANs
    •Multi-VLAN ports Network Port
    •Shared STP instances
    •STP uplink fast for clusters
    •VLAN-based SPAN
    •VLAN Query Protocol
    •VTP Pruning Protocol
    •Web-based management interface
    + những ưu điểm của NM-16ESW
    Cisco EtherSwitch Network Module: Benefits
    •Statistical gains by combining multiple traffic types over a common IP infrastructure.
    •Long distance savings
    •Support for intra-chassis stacking
    •Voice connectivity over data applications
    •IPSec, ACL, VPN and Firewall options
    •New broadband WAN options
    The Interface Range Specification feature makes configuration easier for these reasons:
    •Identical commands can be entered once for a range of interfaces, rather than being entered separately for each interface.
    •Interface ranges can be saved as macros.
    full link:
    Cisco Support Category page for Networking Software (IOS & NX-OS) - My Devices, Support Documentation, Downloads, and End-of-Life Notifications.
    :32::53::X:106:
    Nothing last forever...
